[Geoserver-devel] [jira] Created: (GEOS-1978) Modifying SLD does not appear to take effect without restart
                 Key: GEOS-1978
                 URL: http://jira.codehaus.org/browse/GEOS-1978
             Project: GeoServer
          Issue Type: Bug
            Reporter: Arne Kepp
            Assignee: Justin Deoliveira
            Priority: Minor
             Fix For: 1.7.0
I tested primarily with ExternalGraphic , so the bug may be limited to this, but as far as I can tell you have to restart GeoServer after you edit an SLD, otherwise the old style is still used for subsequent requests.
Note that changing the style of a feature does appear to work.
