[Geoserver-devel] [jira] Created: (GEOS-2015) Crash on startup
Crash on startup
                 Key: GEOS-2015
                 URL: http://jira.codehaus.org/browse/GEOS-2015
             Project: GeoServer
          Issue Type: Task
    Affects Versions: 1.7.0
            Reporter: Arne Kepp
            Assignee: Andrea Aime
            Priority: Minor
             Fix For: 1.7.0
GeoServer went haywire while I was working on the configuration, so I restarted it, and now it fails to start with the following traceback. Could be that I made it take a corrupt SLD, but then this is not a very nice error message. Note that this installation runs gwc,geosearch and rest. Can be a bug in these modules too, this issue is only filed for reference.
Jun 30, 2008 1:56:39 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /opt/actual/jdk1.6.0_04_i586/jre/lib/i386/server:/opt/actual/jdk1.6.0_04_i586/jre/lib/i386:/opt/actual/jdk1.6.0_04_i586/jre/../lib/i386:/usr/java/packages/lib/i386:/lib:/usr/lib
Jun 30, 2008 1:56:39 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Jun 30, 2008 1:56:39 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 522 ms
Jun 30, 2008 1:56:39 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Jun 30, 2008 1:56:39 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.16
Jun 30, 2008 1:56:39 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive geosearch.war
Jun 30, 2008 1:56:40 PM org.apache.catalina.core.StandardContext addApplicationListener
INFO: The listener "org.geoserver.GeoserverInitStartupListener" is already configured for this context. The duplicate definition has been ignored.
INFO: The listener "org.geoserver.logging.LoggingStartupContextListener" is already configured for this context. The duplicate definition has been ignored.
INFO: The listener "org.springframework.web.context.ContextLoaderListener" is already configured for this context. The duplicate definition has been ignored.
30 Jun 13:56:41 INFO [context.ContextLoader] - Root WebApplicationContext: initialization started
30 Jun 13:56:41 INFO [support.XmlWebApplicationContext] - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com: display name [Root WebApplicationContext]; startup date [Mon Jun 30 13:56:41 EDT 2008]; root of context hierarchy
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/var/lib/catalina_webapps/geosearch/WEB-INF/classes/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/geosearch-1.7.0-SNAPSHOT.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/gwc-0.1.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/rest-1.7.0-SNAPSHOT.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/validation-1.7.0-SNAPSHOT.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/wcs-1.7.0-SNAPSHOT.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/wcs1_1-1.7.0-SNAPSHOT.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/wfs-1.7.0-SNAPSHOT.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/wfsv-1.7.0-SNAPSHOT.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/wms-1.7.0-SNAPSHOT.jar!/applicationContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [file:/var/lib/catalina_webapps/geosearch/WEB-INF/classes/applicationSecurityContext.xml]
30 Jun 13:56:41 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationSecurityContext.xml]
30 Jun 13:56:41 INFO [support.XmlWebApplicationContext] - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
30 Jun 13:56:42 INFO [support.XmlWebApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
30 Jun 13:56:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: /var/lib/geoserver_data/geosearch
30 Jun 13:56:42 INFO [support.DefaultListableBeanFactory] - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [applicationState,applicationStateRegisterar,dispatcherMapping,h2DataStoreFactoryInitializer,loggingInitializer,geosearchMapping,sitemap,namespaceindex,feature,gwcGSConfig,gwcDispatcher,gwcTLDispatcher,gwcSeederDispatcher,gwcUrlMapping,gwcServiceWMS,gwcServiceGMaps,gwcServiceMGMaps,gwcServiceVE,gwcServiceKML,gwcCacheFile,gwcCacheKeyFile,gwcCacheKeyFactory,gwcCacheFactory,resourceLoader,extensions,rawCatalog,secureCatalog,geoServer2,geoServerLoader,config,geoServer,globalConfig,data,rawData,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,serviceStrategyFactory,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditorConfigurer,dispatcher,filePublisher,jaiInitializer,restWrapper,restletDispatcherMapping,validation,validationConfig,validationRegisterar,validationConfigRegisterar,wcsLoader,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,wcsService2,wcsServiceDescriptor,wcsExceptionHandler,wcsGetCapabilitiesKvpReader,describeCoverageKvpReader,getCoverageKvpReader,wcsXmlReader,wcsGetCapabilitiesXmlReader,describeCoverageXmlReader,getCoverageXmlReader,wcsGetCapabilitiesResponse,describeCoverageResponse,getCoverageResponse,wcsURLMapping,wcs111ServiceTarget,wcsLogger,wcs111Service,wcsService-1.1.0,wcsService-1.1.1,wcs111URLMapping,wcs111ExceptionHandler,ows11AcceptVersionsKvpParser,ows11SectionsKvpParser,wcs111RangeSubsetKvpParser,wcs111IdentifierKvpParser,wcs111BoundingBoxKvpParser,wcs111GridBaseCRSKvpParser,wcs111TimeSequenceKvpParser,wcs111GridTypeKvpParser,wcs111GridCSKvpParser,wcs111GridOriginKvpParser,wcs111GridOffsetsKvpParser,wcs111GetCapabilitiesKvpReader,wcs111DescribeCoverageKvpReader,wcs111GetCoverageRequestReader,wcs111StoreKvpParser,wcs-1.1.1-configuration,wcs111CapabilitiesRequestReader,wcs111DescribeCoverageRequestReader,wcs111GetCoverageRequestXMLReader,wcs111GetCapabilitiesResponse,wcs111DescribeCoverageResponse,wcs111GetCoverageMultipartResponse,wcs111GetCoverageStoreResponse,wcs111DispatcherMapping,wcs111TempStorageCleaner,wcs111TempStorageCleanerTask,wcs111timerFactory,wfsConfig,wfsRegisterar,wfsConfigRegisterar,filterFactory,wfsLoader,wfs,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElementHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandler,wfsService-1.0.0,wfsService-1.1.0,wfsExceptionHandler,gml2SchemaBuilder,gml3SchemaBuilder,wfsXsd-1.0,xmlConfiguration-1.0,wfsXsd-1.1,xmlConfiguration-1.1,getCapabilitiesResponse,lockFeatureResponse,transactionResponse-1.0.0,geometryResponse,featureResponse,citeComplianceHack,wfsURLMapping,typeNameKvpParser,featureIdKvpParser,bboxKvpParser,filterKvpParser,cqlKvpParser,propertyNameKvpParser,maxFeatureKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpParser,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpReader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,transactionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,lockFeatureXmlReader,transactionXmlReader,xmlReader-1.1.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatureTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1.0,transactionXmlReader-1.1.0,getGmlObjectXmlReader-1.1.0,gml2FeatureTypeEncoder,gml3FeatureTypeEncoder,gml2OutputFormat,gml3OutputFormat,hitsOutputFormat,shapezipOutputFormat,geojsonOutputFormat,wfsvServiceTarget,wfsvService,wfsvService-1.0.0,wfsvService-1.1.0,wfsvExceptionHandler,wfsvURLMapping,wfsvXsd-1.1,wfsvXsd-1.0,wfsvXmlConfiguration-1.1,wfsvXmlConfiguration-1.0,wfsRollbackElementHandler,wfsvVersioned,describeVersionedFeatureTypeKvpReader,getVersionedFeatureKvpRequestReader,wfsv-xmlReader-1.1.0,wfsvDescribeFeatureTypeXmlReader-1.1.0,wfsvGetVersionedFeatureXmlReader-1.1.0,wfsvGetLogXmlReader-1.1.0,wfsvGetDiffXmlReader-1.1.0,wfsvRollbackXmlReader-1.1.0,wfsvVersionedUpdateXmlReader-1.1.0,wfsvDeleteElementXmlReader-1.1.0,wfs-x-xmlReader-1.1.0,wfs-x-TransactionXmlReader-1.1.0,wfsv-xmlReader-1.0.0,wfsvDescribeFeatureTypeXmlReader-1.0.0,wfsvGetVersionedFeatureXmlReader-1.0.0,wfsvGetLogXmlReader-1.0.0,wfsvGetDiffXmlReader-1.0.0,wfsvRollbackXmlReader-1.0.0,wfsvVersionedUpdateXmlReader-1.0.0,wfsvDeleteElementXmlReader-1.0.0,wfs-x-xmlReader-1.0.0,wfs-x-TransactionXmlReader-1.0.0,gml3VersionedFeatureTypeEncoder,gml2VersionedFeatureTypeEncoder,gml2VersionedOutputFormat,transactionOutputFormat,versionedGml3OutputFormat,getLogGml3OutputFormat,getLogGml2OutputFormat,getLogJSONOutputFormat,getLogHtmlOutputFormat,getDiffHtmlOutputFormat,wmsLoader,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsDescribeLayer,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsService2,wmsServiceDescriptor,wmsExceptionHandler,widthKvpParser,heightKvpParser,formatOptionsKvpParser,bgColorKvpParser,transparentKvpParser,tiledKvpParser,tilesOriginKvpParser,bufferKvpParser,paletteKvpParser,timeKvpParser,elevationKvpParser,validateSldKvpParser,sldKvpParser,startIndexKvpParser,wmsGetCapabilitiesKvpReader,describeLayerKvpReader,getMapKvpReader,getFeatureInfoKvpReader,getLegendGraphicKvpReader,wmsCapabilitiesXmlReader,getMapXmlReader,sldXmlReader,wmsGetCapabilitiesResponse,describeLayerResponse,getMapResponse,getFeatureInfoResponse,getLegendGraphicResponse,wmsURLMapping,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLayersMapProducerFactory,GeoRSSMapProducerFactory,kmlService,kmlServiceDescriptor,kmlURLMapping,superOverlayKvpParser,legendKvpParser,kmatrrKvpParser,kmscoreKvpParser,metaTileCache,dataRegionator,sldRegionator,filterChainProxy,restFilterInvocationInterceptor,restFilterDefinitionMap,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,httpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProcessingFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,basicProcessingFilter,basicProcessingFilterEntryPoint,consoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices,authenticationManager,daoAuthenticationProvider,userDetailsService,operationSecurityInterceptor]; root of factory hierarchy
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded namespace 'gbif' (http://www.gbif.org)
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded namespace 'topp' (http://www.openplans.org/topp)
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded namespace 'glc' (http://www.glc.org/)
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded namespace 'landgate' (http://www.landgate.wa.gov.au)
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded namespace 'mgis' (http://www.mass.gov/mgis)
30 Jun 13:56:42 INFO [geoserver.catalog] - Default namespace: 'topp'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'polygon'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'landgate_wcorp'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'point'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'raster'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'mgis_windpower_grid'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'mgis_forest_stewardship'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'glc_zebra_mussel'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'gbif_passer_domesticus'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'line'
30 Jun 13:56:42 INFO [geoserver.catalog] - Loaded style 'glc_glin_benzo'
30 Jun 13:56:42 INFO [geotools.factory] - Factory implementations for category DataStoreFactorySpi:
  org.geotools.data.mysql.MySQLDataStoreFactory
  org.geotools.data.h2.H2DataStoreFactory
  org.geotools.data.postgis.PostgisDataStoreFactory
  org.geotools.data.postgis.VersionedPostgisDataStoreFactory
  org.geotools.data.property.PropertyDataStoreFactory
  org.geotools.data.shapefile.ShapefileDataStoreFactory
  org.geotools.data.wfs.WFSDataStoreFactory
30 Jun 13:56:42 INFO [geoserver.catalog] - Processed data store 'gbif', enabled
30 Jun 13:56:42 INFO [geoserver.catalog] - Processed data store 'glc', enabled
30 Jun 13:56:42 INFO [geoserver.catalog] - Processed data store 'mgis', enabled
30 Jun 13:56:42 INFO [geotools.factory] - Factory implementations for category FilterFactory:
  org.geotools.filter.FilterFactoryImpl
30 Jun 13:56:42 INFO [geotools.factory] - Factory implementations for category CRSFactory:
  org.geotools.referencing.factory.ReferencingObjectFactory
30 Jun 13:56:42 INFO [geotools.factory] - Factory implementations for category MathTransformFactory:
  org.geotools.referencing.operation.DefaultMathTransformFactory
30 Jun 13:56:42 INFO [geotools.factory] - Factory implementations for category DatumFactory:
  org.geotools.referencing.factory.DatumAliases
30 Jun 13:56:42 INFO [geotools.factory] - Factory implementations for category CSFactory:
30 Jun 13:56:42 INFO [geotools.factory] - Factory implementations for category CRSAuthorityFactory:
  org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory
  org.geotools.referencing.factory.epsg.DefaultFactory
  org.geotools.referencing.factory.epsg.FactoryUsingWKT
  org.geotools.referencing.factory.epsg.LongitudeFirstFactory
  org.geotools.referencing.factory.wms.AutoCRSFactory
  org.geotools.referencing.factory.wms.WebCRSFactory
  org.geotools.referencing.factory.URN_AuthorityFactory
  org.geotools.referencing.factory.HTTP_AuthorityFactory
  org.geotools.referencing.factory.epsg.LongitudeFirstEpsgDecorator
  org.vfny.geoserver.crs.GeoserverCustomWKTFactory
30 Jun 13:56:43 INFO [referencing.factory] - Connected to EPSG database "jdbc:hsqldb:file:/opt/tomcat-6.0/temp/Geotools/Databases/HSQL/EPSG" on "HSQL Database Engine".
30 Jun 13:56:43 INFO [referencing.factory] - Using "/var/lib/geoserver_data/geosearch/user_projections/epsg.properties" as EPSG factory.
30 Jun 13:56:43 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295], AXIS["Longitude", EAST], AXIS["Latitude", NORTH]], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","900913"]]
30 Jun 13:56:43 INFO [geoserver.catalog] - Loaded feature type 'glc:glin_zebra_mussel'
30 Jun 13:56:43 INFO [geotools.factory] - Factory implementations for category MathTransformProvider:
  org.geotools.referencing.operation.transform.LogarithmicTransform1D$Provider
  org.geotools.referencing.operation.transform.ExponentialTransform1D$Provider
  org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderAffine
  org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderLongitudeRotation
  org.geotools.referencing.operation.transform.GeocentricTranslation$Provider
  org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderSevenParam
  org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderFrameRotation
  org.geotools.referencing.operation.transform.GeocentricTransform$Provider
  org.geotools.referencing.operation.transform.GeocentricTransform$ProviderInverse
  org.geotools.referencing.operation.transform.MolodenskiTransform$Provider
  org.geotools.referencing.operation.transform.MolodenskiTransform$ProviderAbridged
  org.geotools.referencing.operation.transform.NADCONTransform$Provider
  org.geotools.referencing.operation.transform.WarpTransform2D$Provider
  org.geotools.referencing.operation.projection.EquidistantCylindrical$Provider
  org.geotools.referencing.operation.projection.PlateCarree$Provider
  org.geotools.referencing.operation.projection.Mercator1SP$Provider
  org.geotools.referencing.operation.projection.Mercator2SP$Provider
  org.geotools.referencing.operation.projection.TransverseMercator$Provider
  org.geotools.referencing.operation.projection.TransverseMercator$Provider_SouthOrientated
  org.geotools.referencing.operation.projection.ObliqueMercator$Provider
  org.geotools.referencing.operation.projection.ObliqueMercator$Provider_TwoPoint
  org.geotools.referencing.operation.projection.HotineObliqueMercator$Provider
  org.geotools.referencing.operation.projection.HotineObliqueMercator$Provider_TwoPoint
  org.geotools.referencing.operation.projection.AlbersEqualArea$Provider
  org.geotools.referencing.operation.projection.LambertConformal1SP$Provider
  org.geotools.referencing.operation.projection.LambertConformal2SP$Provider
  org.geotools.referencing.operation.projection.LambertConformalBelgium$Provider
  org.geotools.referencing.operation.projection.LambertConformalESRI$Provider
  org.geotools.referencing.operation.projection.LambertAzimuthalEqualArea$Provider
  org.geotools.referencing.operation.projection.Orthographic$Provider
  org.geotools.referencing.operation.projection.Stereographic$Provider
  org.geotools.referencing.operation.projection.ObliqueStereographic$Provider
  org.geotools.referencing.operation.projection.PolarStereographic$ProviderA
  org.geotools.referencing.operation.projection.PolarStereographic$ProviderB
  org.geotools.referencing.operation.projection.PolarStereographic$ProviderNorth
  org.geotools.referencing.operation.projection.PolarStereographic$ProviderSouth
  org.geotools.referencing.operation.projection.NewZealandMapGrid$Provider
  org.geotools.referencing.operation.projection.Krovak$Provider
  org.geotools.referencing.operation.projection.Mercator1SPGoogle$Provider
30 Jun 13:56:43 INFO [geoserver.catalog] - Loaded feature type 'mgis:windpower_grid'
30 Jun 13:56:43 INFO [geoserver.catalog] - Loaded feature type 'gbif:passer_domesticus'
30 Jun 13:56:43 INFO [geoserver.catalog] - Loaded feature type 'mgis:forest_stewardship'
30 Jun 13:56:43 INFO [geoserver.catalog] - Loaded feature type 'glc:glin_benzo'
30 Jun 13:56:43 INFO [geoserver.confg] - Loading service 'wcs'
30 Jun 13:56:43 INFO [geoserver.confg] - Loading service 'wfs'
30 Jun 13:56:43 INFO [geoserver.confg] - Loading service 'wms'
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
30 Jun 13:56:44 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
30 Jun 13:56:44 INFO [geoserver.global] - Done disposing datastores.
30 Jun 13:56:44 INFO [geoserver.catalog] - Disposing datastore 'glc'
30 Jun 13:56:44 INFO [geoserver.catalog] - Disposing datastore 'mgis'
30 Jun 13:56:44 INFO [geoserver.catalog] - Disposing datastore 'gbif'
30 Jun 13:56:44 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sitemap' defined in URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/geosearch-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'dataConfig' while setting bean property 'dataConfig'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dataConfig' defined in URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.DataConfig]: Constructor threw exception; nested exception is java.lang.reflect.UndeclaredThrowableException
Related cause: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'dataConfig' defined in URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Unsatisfied dependency expressed through constructor argument with index 0 of type [org.vfny.geoserver.global.dto.DataDTO]: Could not convert constructor argument value of type [org.vfny.geoserver.global.Data] to required type [org.vfny.geoserver.global.dto.DataDTO]: Failed to convert value of type [org.vfny.geoserver.global.Data] to required type [org.vfny.geoserver.global.dto.DataDTO]; nested exception is java.lang.IllegalArgumentException: Cannot convert value of type [org.vfny.geoserver.global.Data] to required type [org.vfny.geoserver.global.dto.DataDTO]: no matching editors or conversion strategy found
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1210)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:978)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:462)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:404)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:375)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:263)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:170)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:260)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:184)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:163)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:430)
  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
  at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:254)
  at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:198)
  at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
  at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3843)
  at org.apache.catalina.core.StandardContext.start(StandardContext.java:4350)
  at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
  at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
  at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:525)
  at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:829)
  at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:718)
  at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:490)
  at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1147)
  at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
  at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:117)
  at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
  at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
  at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
  at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
  at org.apache.catalina.core.StandardService.start(StandardService.java:516)
  at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
  at org.apache.catalina.startup.Catalina.start(Catalina.java:578)
  at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
  at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dataConfig' defined in URL [jar:file:/var/lib/catalina_webapps/geosearch/WEB-INF/lib/main-1.7.0-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.DataConfig]: Constructor threw exception; nested exception is java.lang.reflect.UndeclaredThrowableException
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:243)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:893)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:803)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:437)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
  ... 42 more
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.vfny.geoserver.config.DataConfig]: Constructor threw exception; nested exception is java.lang.reflect.UndeclaredThrowableException
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:99)
  at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:237)
  ... 54 more
Caused by: java.lang.reflect.UndeclaredThrowableException
  at $Proxy8.getStyle(Unknown Source)
  at org.vfny.geoserver.global.FeatureTypeInfo.getDefaultStyle(FeatureTypeInfo.java:600)
  at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:437)
  at org.vfny.geoserver.global.Data.toDTO(Data.java:1588)
  at org.vfny.geoserver.config.DataConfig.<init>(DataConfig.java:220)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:84)
  ... 56 more
Caused by: java.lang.reflect.InvocationTargetException
  at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:87)
  ... 66 more
Caused by: java.lang.NullPointerException
  at java.io.FileInputStream.<init>(FileInputStream.java:103)
  at org.geotools.styling.SLDParser.setInput(SLDParser.java:221)
  at org.geotools.styling.SLDParser.<init>(SLDParser.java:146)
  at org.geoserver.catalog.ResourcePool.getStyle(ResourcePool.java:588)
  at org.geoserver.catalog.impl.StyleInfoImpl.getStyle(StyleInfoImpl.java:48)
  ... 71 more
Related cause:
  at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:544)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:190)
