[Geoserver-devel] [jira] Created: (GEOS-2054) Wms Reflect not correctly reproiecting layer from srs=epsg:3003 to srs=epsg:4326
                 Key: GEOS-2054
                 URL: http://jira.codehaus.org/browse/GEOS-2054
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.0-beta1
         Environment: Geoserver GeoServer 1.7.0-beta1 deployed on Ubuntu 8.04 server, Postgres 8.3 + Postgis 1.3
            Reporter: Francesco Izzi
            Assignee: Andrea Aime
             Fix For: 1.7.0-beta2
I try to reproiect layers with wms reflect.
The layers was loaded with srs = 3003 and is correctly.
The examples is
http://151.13.182.117/geoserver/wms?bbox=2472705.6702105394,4503256.589468379,2665078.321847044,4718283.534841086&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=agea:foggia_fogli&width=542&height=550&srs=EPSG:3003
but when i try to reproiect this layer in srs=epsg:4326 with
http://151.13.182.117/geoserver/wms/reflect?layers=agea:foggia_fogli&srs=epsg:4326&format=application/openlayers&width=800&height=400
i not have any responce.
i see the geoserver log and i find this
2008-07-22 18:55:44,425 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Expression request.SRS is undefined on line 140, column 36 in OpenLayersMapTemplate.ftl.
        at org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapProducer.writeTo(OpenLayersMapProducer.java:120)
        at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:566)
        at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:648)
        at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:198)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
        at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
        at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
        at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
        at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
