[Geoserver-devel] [jira] Created: (GEOS-2174) New catalog does not appear to be sending events to listeners
                 Key: GEOS-2174
                 URL: http://jira.codehaus.org/browse/GEOS-2174
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.7.0-RC1
            Reporter: Arne Kepp
            Assignee: Justin Deoliveira
             Fix For: 1.7.0
It looks like the new catalog does not send events to listeners (or I'm using it incorrectly). I have verified that the constructor in the code snippet below is called and appears to . I have also tried using the bean catalog2 (aka securedcatalog), same result.
To test I then logged into the admin interface and change featuretype and styles. None of submit, apply, save, load had any effect.
--------- Spring bean definition:
<bean id="gwcCatalogListener" class="org.geoserver.gwc.GWCCatalogListener">
  <constructor-arg type="org.geoserver.catalog.Catalog" ref="rawCatalog" />
</bean>
--------- Java code:
package org.geoserver.gwc;
import org.geoserver.catalog.Catalog;
import org.geoserver.catalog.event.CatalogAddEvent;
import org.geoserver.catalog.event.CatalogListener;
import org.geoserver.catalog.event.CatalogModifyEvent;
import org.geoserver.catalog.event.CatalogRemoveEvent;
public class GWCCatalogListener implements CatalogListener {
    public GWCCatalogListener(Catalog cat) {
        cat.addListener(this);
    public void handleAddEvent(CatalogAddEvent event) {
        // TODO Auto-generated method stub
        System.out.println(event);
    public void handleModifyEvent(CatalogModifyEvent event) {
    public void handleRemoveEvent(CatalogRemoveEvent event) {
