Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/browse/GEOS-219
Here is an overview of the issue:
Key: GEOS-219
Summary: Better handling of Intersect
Type: Improvement
Status: Open
Priority: Minor
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Components:
Error Reporting
Fix Fors:
1.2.3
Versions:
1.2.2
Assignee: Chris Holmes
Reporter: Chris Holmes
Created: Thu, 7 Oct 2004 9:02 AM
Updated: Thu, 7 Oct 2004 9:02 AM
Description:
The ogc spec is a bit unclear about Intersect vs. Intersects for the filter. In the capabilities document it is Intersects, but the actual filter seems to be Intersects. GeoServer uses Intersects, but it doesn't return an error if Intersect is used. Instead it silently ignores it. We should either report the error, or else just interpret Intersect as Intersects.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
