SDE layer doesn't show up in KML
Key: GEOS-2196
URL: http://jira.codehaus.org/browse/GEOS-2196
Project: GeoServer
Issue Type: Bug
Components: ArcSDE, Google Earth KML Output
Affects Versions: 1.7.0-RC2
Environment: Windows XP, Tomcat 6.0
Reporter: Amr A. Alam
Assignee: Andrea Aime
I have 2 SDE layers set up in Geoserver. They will randomly show up in Google Earth, and other times will result in the red (not working) icon.
The Geoserver logs always shows a exceptions whether the layers show up or not. Here's one of the exceptions triggered by requesting an SDE layer in GE:
2008-09-04 13:00:50,812 ERROR [arcsde.pool] - Command execution failed for Session 2 in thread 13
org.geotools.arcsde.ArcSdeException: [SDE error -288][Error desc=LOGFILE SYSTEM TABLES DO NOT EXIST. ][Extended desc=
at org.geotools.arcsde.pool.Session$2.call(Session.java:204)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: com.esri.sde.sdk.client.SeException:
at com.esri.sde.sdk.client.k.a(Unknown Source)
at com.esri.sde.sdk.client.SeQuery.calculateTableStatistics(Unknown Source)
at org.geotools.arcsde.data.ArcSDEQuery$3.execute(ArcSDEQuery.java:613)
at org.geotools.arcsde.data.ArcSDEQuery$3.execute(ArcSDEQuery.java:610)
at org.geotools.arcsde.pool.Session$2.call(Session.java:201)
... 5 more
2008-09-04 13:02:05,468 ERROR [geoserver.ows] -
java.io.IOException
at org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer.writeTo(KMZMapProducer.java:153)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:560)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:648)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:198)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer.writeTo(KMZMapProducer.java:150)
... 52 more
Caused by: java.lang.IllegalStateException: Cannot create a session after the response has been committed
at org.apache.catalina.connector.Request.doGetSession(Request.java:2301)
at org.apache.catalina.connector.Request.getSession(Request.java:2075)
at org.apache.catalina.connector.RequestFacade.getSession(RequestFacade.java:833)
at org.apache.catalina.connector.RequestFacade.getSession(RequestFacade.java:844)
at org.vfny.geoserver.util.Requests.getBaseUrl(Requests.java:92)
at org.geoserver.wms.util.WMSRequests.getBaseUrl(WMSRequests.java:48)
at org.geoserver.wms.util.WMSRequests.getBaseUrl(WMSRequests.java:63)
at org.geoserver.wms.util.WMSRequests.getGetLegendGraphicUrl(WMSRequests.java:203)
at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.getLegendGraphicUrl(KMLUtils.java:146)
at org.vfny.geoserver.wms.responses.map.kml.KMLLegendTransformer$KMLLegendTranslator.encode(KMLLegendTransformer.java:63)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeLegend(KMLTransformer.java:260)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:155)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
... 54 more
