[Geoserver-devel] [jira] Created: (GEOS-2261) KMLReflector still using the deprecated class
                 Key: GEOS-2261
                 URL: http://jira.codehaus.org/browse/GEOS-2261
             Project: GeoServer
          Issue Type: Bug
          Components: Google Earth KML Output
            Reporter: Alessio Fabiani
            Assignee: Alessio Fabiani
            Priority: Minor
             Fix For: 1.7.x, 2.0.x
It looks like GeoServer still uses the deprecated Class:
org.vfny.geoserver.wms.servlets.KMLReflector
instead of:
org.vfny.geoserver.wms.responses.map.kml.KMLReflector
Is it that behavior expected?
The deprecated Class moreover causes an unexpected error when expanding the default bounding box to the Google Earth tile. In particular if the below layer has a native bounding box expressed in a CRS which cannot be projected on certain Earth areas (for instance Mercator near the Poles), causes an projection exception.
