[Geoserver-devel] [jira] Created: (GEOS-2266) add some kml tests
add some kml tests
                 Key: GEOS-2266
                 URL: http://jira.codehaus.org/browse/GEOS-2266
             Project: GeoServer
          Issue Type: Improvement
    Affects Versions: 1.7.0-RC3
            Reporter: Justin Deoliveira
            Assignee: David Winslow
            Priority: Critical
             Fix For: 1.7.0-RC4
Currently we have zero kml tests. And there is really no part of the manuall hand testing of a release which tests it either. This has caused a number of regressions with regard to KML on 1.7.x.
We need to implement at least a few tests for 1.7.x It does not have to be comprehensive coverage at this point... just a way to ensure that things are not completely broken.
