Cleanup GeoServerExtensions when functional/integration tests end
Key: GEOS-2273
URL: http://jira.codehaus.org/browse/GEOS-2273
Project: GeoServer
Issue Type: Bug
Components: WMS
Reporter: Andrea Aime
Assignee: Andrea Aime
When maven is running the tests it won't unload classes between one and the other, meaning GeoServerExtensions might be initialized by one test and then used in that state by other tests, eventually with an old and closed app context.
This affects unit tests that are executed after integration tests, such as GetMapTest.
