MIN_GOODNESS_FIT causing labels to be missed off.
Key: GEOS-2372
URL: http://jira.codehaus.org/browse/GEOS-2372
Project: GeoServer
Issue Type: Improvement
Affects Versions: 1.6.3
Environment: N/A
Reporter: Darren
Assignee: Andrea Aime
Priority: Minor
Complex layers containing multiple intersecting polygons cause their associated labels to not always be displayed. This is due to the MIN_GOODNESS_FIT parameter that is a threshold for displaying labels for points/line/polygons. This parameter is hidden away in the depths of geotools. It should be made possible to override this parameter so that labels are always visible no matter what the goemetry or complexity for instances when it is required. This could be configurable on a per layer basis within the "featuretype" definition of geoserver. Alternatively the definition could be stored within the SLD used to render the featuretype if the SLD spec allows.
