[Geoserver-devel] [jira] Created: (GEOS-2454) Attempting to validate GetFeature results with xsd Parser fails
                 Key: GEOS-2454
                 URL: http://jira.codehaus.org/browse/GEOS-2454
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 2.0.x
I've tried to validate a GetFeature output with Parser, but the result refers a schema that cannot be reached:
{code}
org.xml.sax.SAXException: error validating
  at org.geotools.xml.impl.ParserHandler.startElement(ParserHandler.java:306)
  at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
  at org.apache.xerces.impl.xs.XMLSchemaValidator.startElement(Unknown Source)
  at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
  at org.apache.xerces.impl.XMLNSDocumentScannerImpl$NSContentDispatcher.scanRootElementHook(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
  at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
  at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
  at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
  at org.geotools.xml.Parser.parse(Parser.java:221)
  at org.geotools.xml.Parser.parse(Parser.java:149)
  at org.geotools.xml.Parser.parse(Parser.java:198)
  at org.geoserver.wfs.WFSTestSupport.checkValidationErrors(WFSTestSupport.java:84)
  at org.geoserver.wfs.GetFeatureTest.testFeatureBoundingEnabled(GetFeatureTest.java:162)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:129)
  at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestReference.run(JUnit3TestReference.java:130)
  at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:460)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:673)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:386)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:196)
Caused by: java.io.FileNotFoundException: http://localhost:80/geoserver/wfs?service=WFS&version=1.0.0&request=DescribeFeatureType&typeName=cite:Forests
  at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1168)
  at org.apache.xerces.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
  at org.apache.xerces.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
  at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
  at javax.xml.parsers.SAXParser.parse(SAXParser.java:255)
  at org.geotools.xml.Schemas.validateImportsIncludes(Schemas.java:288)
  at org.geotools.xml.Schemas.validateImportsIncludes(Schemas.java:258)
  at org.geotools.xml.impl.ParserHandler.startElement(ParserHandler.java:303)
  ... 32 more
{code}
Any suggestion on how to work around this? The configuration comes from WFSTestSupport.getXmlConfiguration11()
so it has a reference to the feature type builders... maybe I'm missing some glue there...
Besides that, the validation code is a copy of the one you provided for WPSTestSupport.
