[Geoserver-devel] [jira] Created: (GEOS-2461) Default WFS outputFormat stated as text/gml; subtype=gml/3.1.1 instead of text/xml; subtype=gml/3.1.1
                 Key: GEOS-2461
                 URL: http://jira.codehaus.org/browse/GEOS-2461
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 2.0-alpha1, 1.7.0-RC4, 1.6.5
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 1.7.2, 2.0.x
The spec says the WFS 1.1 default output format is "text/xml; subtype=gml/3.1.1", but we have a typo on out capabilities: "text/gml; subtype=gml/3.1.1" (note we state text/gml instead of text/xml). This is problematic for standard clients.
This happens to the operations DescribeFeatureType, GetFeature, GetFeatureWithLock and Transaction. The operation metadata section for each of them states, but then the FeatureType specific supported output formats contain the correct mime type {{text/xml; subtype=gml/3.1.1}}
{code}
<ows:Parameter name="resultType">
<ows:Value>results</ows:Value>
<ows:Value>hits</ows:Value>
</ows:Parameter>
{code}
