[Geoserver-devel] [jira] Created: (GEOS-2465) KML output fails if no strategy name is specified in request and config has a empty string value
                 Key: GEOS-2465
                 URL: http://jira.codehaus.org/browse/GEOS-2465
             Project: GeoServer
          Issue Type: Bug
          Components: Google Earth KML Output
            Reporter: Justin Deoliveira
            Assignee: Justin Deoliveira
             Fix For: 1.7.1
this is happening b/c someone keeps committing an info.xml with <regionateStrategy value = "" />. Not sure why this is happening but the code should be less brittle. The current code only checks for null and then sets "best_guess". It should handle the empty string as well.
