[Geoserver-devel] [jira] Created: (GEOS-2466) Windows installer creates incorrect path to Java
                 Key: GEOS-2466
                 URL: http://jira.codehaus.org/browse/GEOS-2466
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.0
            Reporter: Arne Kepp
            Assignee: Mike Pumphrey
            Priority: Minor
             Fix For: 1.7.1
Someone needs to verify this before we take it seriously, but I installed GeoServer 1.7.0a on a machine that has never had GeoServer or anything like it on it. JRE 1.5.0 was already installed. (We need JDK for the GUI, don't we ?)
Either way, the issue is that the installer creates incorrect shortcuts in the start menu, linking to [JAVA HOME]\bin\bin\java.exe, when it should be [JAVA HOME]\bin\java.exe
I've labeled it as minor because Windows XP SP2 offers to fix the link right away, so if you don't have too many versions of Java installed it shouldn't really be a problem.
