[Geoserver-devel] [jira] Created: (GEOS-2557) Have file publisher redirect directory references to a default file
                 Key: GEOS-2557
                 URL: http://jira.codehaus.org/browse/GEOS-2557
             Project: GeoServer
          Issue Type: Improvement
          Components: Global
    Affects Versions: 1.7.1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.7.2
When one points to a directory below www directoy, the file publisher responds that it does not know about its mime type.
Have it redirect to index.html or index.htm if available, instead.
Shall we also consider listing the contents of directories that do not have such files?
