CatalogImpl.validate(ResourceInfo, false) does not handle name change
Key: GEOS-2812
URL: http://jira.codehaus.org/browse/GEOS-2812
Project: GeoServer
Issue Type: Bug
Components: Configuration
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 2.0.x
From the ml:
While looking into CatalogImpl.validate(ResourceInfo) I also noticed
the name validation occurs only if the layer is new... which does
not look like a good idea, as people can change the name afterwards
as well, and make it collide with another layer. The code should
check if the catalog already contains a resource with the same name
in the same workspace, and pass only if none is found, or if the
resource found is different from the one at hand (which requires
some id based comparison, with an id different than the name)...
