Running Geoserver 2.0-alpha2 first time causes IllegalArgumentExceptions
Key: GEOS-2959
URL: http://jira.codehaus.org/browse/GEOS-2959
Project: GeoServer
Issue Type: Bug
Environment: Ubuntu Jaunty
Linux 2.6.28-11-generic #42-Ubuntu SMP Fri Apr 17 01:58:03 UTC 2009 x86_64 GNU/Linux
Reporter: Tim Coulter
Assignee: Andrea Aime
Installing and then running Geoserver 2.0-alpha2 on an Ubuntu Jaunty for the first time causes two IllegalArgumentExceptions.
Steps to reproduce:
1) Download Geoserver from the link given above.
2) Extract the zip file to a desired location, then cd into 'geoserver-2.0-alpha2/bin' and run startup.sh.
3) As Geoserver starts up, notice the two exceptions listed below.
As far as I can tell, these errors are only cosmetic as I have not researched their consequences. However, my hunch tells me IllegalArgumentExceptions are generally cause for alarm.
Oddly, these exceptions only show up the first time Geoserver is started.
The exceptions:
java.lang.IllegalArgumentException: Resource named 'Arc_Sample' already exists in store: 'arcGridSample'
at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:362)
at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:341)
at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:253)
at org.geoserver.config.GeoServerLoader.readLegacyCatalog(GeoServerLoader.java:658)
at org.geoserver.config.GeoServerLoader.loadCatalog(GeoServerLoader.java:159)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:125)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
29 Apr 15:46:49 WARN [geoserver.catalog] - Error loading 'img_sample2_Pk50095/info.xml', ignoring
29 Apr 15:46:49 INFO [geoserver.catalog] -
java.lang.IllegalArgumentException: Resource named 'Pk50095' already exists in store: 'img_sample2'
