[Geoserver-devel] [jira] Created: (GEOS-3088) A SoreInfo can't be saved if the coverage/data store can't be accessed. Not even to just disable the store
                 Key: GEOS-3088
                 URL: http://jira.codehaus.org/browse/GEOS-3088
             Project: GeoServer
          Issue Type: Bug
          Components: Wicket UI
    Affects Versions: 2.0-beta1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0-beta2
Say you have a data store configured but the server it hits is down, so you want to disable the store.
Go to the store's edit page and uncheck the enabled checkbox, it can't be saved if the datastore is not accessible.
When connection parameters are wrong, it would be better to inform the user and ask him if still wishes to save the store info as is.
