[Geoserver-devel] [jira] Created: (GEOS-3093) items in the metadata map do not round trip type
                 Key: GEOS-3093
                 URL: http://jira.codehaus.org/browse/GEOS-3093
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0-beta1
            Reporter: Justin Deoliveira
            Assignee: Justin Deoliveira
             Fix For: 2.0-beta2
The problem is that the xstream persister drops any type information in the interest of keeping the map contents less verbose. The rationale here was for the rest config.
The work around for now is that code that does:
(Integer) xyz.getMetadata().get( "foobar")
Can do this:
Converters.convert( xyz.getMetadata().get( "foobar"), Integer.class )
But it would be nicer if the information was preserved. See GEOS-3092.
