[Geoserver-devel] [jira] Created: (GEOS-3175) Add support for DirectConnect in ArcSDE datastore
                 Key: GEOS-3175
                 URL: http://jira.codehaus.org/browse/GEOS-3175
             Project: GeoServer
          Issue Type: Wish
          Components: ArcSDE
    Affects Versions: 1.7.x
         Environment: ArcSDE 9.2, Oracle 10g
            Reporter: Gerhard Sommer
            Assignee: Andrea Aime
We need to change all ArcSDE connections to DirectConnect, because we need to make the database redundant and connections using the ArcSDE server are a single point of failure.
this is no problem in ArcGIS Desktop, but currently GeoServer seems not to support this connection option. Is it possible to add support for DirectConnect?
     [ http://jira.codehaus.org/browse/GEOS-3175?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Gabriel Roldán reopened GEOS-3175:
reopening so it doesn't look like fixed, will add a dependency on the corresponding geotools issue.
                Key: GEOS-3175
            Project: GeoServer
         Issue Type: Wish
         Components: ArcSDE
           Assignee: Gabriel Roldán
