Avoid using getTextContent/setTextContent
Key: GEOS-3230
URL: http://jira.codehaus.org/browse/GEOS-3230
Project: GeoServer
Issue Type: Improvement
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.0-beta2
Attachments: GEOS-3230.patch
Maven eclipse plugin starting from version 2.6 generates the classpath in a different order than the previous versions, putting test dependencies first (and src/test before src/main in the tree).
This results in xml-apis jar being moved up in the classpath list, and breaks compilation under Eclipse, due to the getTextContent/setTextContent being used in the sources but not declared in such jar (neither in the version we're using, nor in version 2.0.2).
Getting rid of the xml-apis dependency does not seem to be easy (tried and failed, someone else may have better luck), but the two methods cites above can be simply avoided and replacements used instead.
The attached patch uses replacement to make GeoServer compile again xml-apis without breaking the build neither in maven nor in Eclipse.
