ShapeZipOutputFormat cannot handle long shapefile incompatible schemas
Key: GEOS-3235
URL: http://jira.codehaus.org/browse/GEOS-3235
Project: GeoServer
Issue Type: Improvement
Components: WFS
Affects Versions: 1.7.5
Reporter: Mauro Bartolomeoli
Assignee: Andrea Aime
Priority: Minor
Fix For: 1.7.x
Attachments: patch.zip
Currently exporting shapefiles via WFS (outputFormat="SHAPE-ZIP") is not possible (Exceptions are thrown) if the source FeatureCollection has a schema which is not compatible with shapefile datastore/featurestore constraints such as:
1) the geometry attribute has to be named the_geom
2) the field names have to be shorter than 10 characters
In the attached a patch to ShapeZipOutputFormat, together with a new RemappingFeatureCollection class (also attached) tries to handle those cases.
A test case is also included.
