Troubles changing CRS for simple feature
Key: GEOS-3307
URL: http://jira.codehaus.org/browse/GEOS-3307
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 2.0.x
Environment: GeoServer 2.0 (nightly build)
Microsoft Internet Explorer v8.0
Google Chrome v2.0.172.37
Reporter: Pavel Golodoniuc
Assignee: Andrea Aime
I'm having troubles configuring Declared SRS property of a simple feature from GeoServer admin web interface in major browsers.
When typing desired SRS (EPSG:4283) in that field and attempting to save changes GeoServer simply ignores user input and rolles back this change to the previous state. An attempt to use "Find CRS" window has failed as well in MSIE and Chrome. When invoking search function in the popup window it shows an alert with the following message:
Are you sure want to navigate away frmo this page?
Reloading this page will cause the modal window to disappear.
Press OK to continue, or Cancel to stay on the current page.
[ https://jira.codehaus.org/browse/GEOS-3307?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Pavel Golodoniuc reopened GEOS-3307:
The issue has been re-tested once again and confirmed on the following GeoServer builds:
Version2.1-SNAPSHOT
Subversion Revision15199
Build Date17-Jan-2011 12:29
GeoTools Version2.7-SNAPSHOT (rev 36411)
and
Version2.2-SNAPSHOT
Subversion Revision15783
Build Date03-May-2011 23:51
GeoTools Version8-SNAPSHOT (rev 37069)
Both builds have been tested on IE 9.0.8112.16421 and Chrome 12.0.742.112.
To reproduce the error I have performed the following steps:
1. Created a new workspace.
2. Created a new Oracle NG datastore.
3. Created a new layer from a simple database view.
4. Clicked the "Find" button near "Declared SRS" field.
5. In the pop-up window typed "GDA" in the search box and pressed Enter.
PS. Screenshots are attached...
Key: GEOS-3307
URL: https://jira.codehaus.org/browse/GEOS-3307
Project: GeoServer
Issue Type: Bug
Components: UI
Affects Versions: 2.0.2, 2.1-RC1
Attachments: image001.jpg, image002.jpg
