[Geoserver-devel] [jira] Created: (GEOS-3423) Antialiased rendering scales up poorly
                 Key: GEOS-3423
                 URL: http://jira.codehaus.org/browse/GEOS-3423
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 2.0.x
This is due to a limitation in Sun own renderer:
http://bugs.sun.com/view_bug.do?bug_id=6508591
The only known workaround is to run multiple GeoServer instances under a load balancer (multiple instances on the same multicore machine, that is).
Other approaches might be looked into, like rendering 2 or 4 times bigger images without antialiasing and then perform reduction with bilinear/bicubic interpolation, thought I doubt the results will be any good.
