problem with SRS EPSG:32662
Key: GEOS-3526
URL: http://jira.codehaus.org/browse/GEOS-3526
Project: GeoServer
Issue Type: Bug
Components: WMS
Environment: windows
Reporter: Jeremy Trudel
Assignee: Andrea Aime
Fix For: 1.7.6
I downloaded and am running GeoServer 1.7.6. I ma using the map data that came with the standard install. When I do a getCapabilities request on the WMS server:
http://localhost:8080/geoserver/wms?request=getCapabilities
I get an xml file that stated that SRS EPSG:32662 is a supported format,but when I do a getMap Request:
I get a projection not supported exception:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd"> <ServiceExceptionReport version="1.1.1" > <ServiceException code="InvalidSRS">
Error occurred decoding the espg code EPSG:32662
Elliptical projection not supported.
</ServiceException></ServiceExceptionReport>
Does it not state in the OGC WMS specification that you must support all coordinate reference systems that are supplied with the getCapabilities request?
