[Geoserver-devel] [jira] Created: (GEOS-3600) WMS Performance degrades after >20000 requests served
                 Key: GEOS-3600
                 URL: http://jira.codehaus.org/browse/GEOS-3600
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0-RC2
         Environment: tomcat6, ubuntu, java 1.6, AMD 2 core, 6GB ram, postgisng and also on macosx budle, postgisng (macports),
            Reporter: Thomas
            Assignee: Andrea Aime
I tested tile generation on maxosx and tomcat6/LINUX (2GB java heap) in both cases I used the system to generate 300000 tiles sequentially from postgis over the whole map in different zooms. Somehow GeoServer leaks memory and fills up the 2GB heap. If that happens, WMS tile generation speed drops slowly down from, for example, 100 per minute to 5 per minute but still uses 100% CPU. At that point most of the java memory is full.
Speed can be reclaimed temporarily (about 20000 more tiles) by going to the Status page and clearing the Resource Cache followed by several clicks on Free Memory. If memory congestion is too bad, the Status page takes forever to open and resetting memory becomes difficult. Geoserver needs intervention about every 30 minutes to 1h depending on available memory.
A workaround would be an automated way to invoke these cleanup functions after a specific number of requests.
