REST request to get coverages metadata in json format
Key: GEOS-3611
URL: http://jira.codehaus.org/browse/GEOS-3611
Project: GeoServer
Issue Type: Bug
Components: REST
Affects Versions: 2.0.0
Environment: Windows Vista
Reporter: Tobia Di Pisa
Assignee: Andrea Aime
Fix For: 2.0.1
I have found a problem in GeoServer REST request to get coverages metadata in json format.
If I send the following request:
http://localhost:8080/geoserver/rest/workspaces/nurc/coveragestores/mosaic/coverages/mosaic.json
GeoServer produces an exception as the following:
28 ott 18:33:45 ERROR [/geoserver] - Exception intercepted
com.thoughtworks.xstream.io.StreamException: : null
at com.thoughtworks.xstream.io.xml.StaxWriter.setValue(StaxWriter.java:122)
at com.thoughtworks.xstream.converters.SingleValueConverterWrapper.marshal(SingleValueConverterWrapper.java:45)
at com.thoughtworks.xstream.core.TreeMarshaller.convert(TreeMarshaller.java:86)
at com.thoughtworks.xstream.core.TreeMarshaller.convertAnother(TreeMarshaller.java:78)
at com.thoughtworks.xstream.core.TreeMarshaller.convertAnother(TreeMarshaller.java:63)
at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.writeItem(AbstractCollectionConverter.java:64)
at com.thoughtworks.xstream.converters.collections.MapConverter.marshal(MapConverter.java:58)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.marshallField(AbstractReflectionConverter.java:157)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$2.writeField(AbstractReflectionConverter.java:148)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$2.visit(AbstractReflectionConverter.java:118)
at org.geoserver.config.util.XStreamPersister$CustomReflectionProvider$VisitorWrapper.visit(XStreamPersister.java:469)
at com.thoughtworks.xstream.converters.reflection.PureJavaReflectionProvider.visitSerializableFields(PureJavaReflectionProvider.java:129)
at org.geoserver.config.util.XStreamPersister$CustomReflectionProvider.visitSerializableFields(XStreamPersister.java:445)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doMarshal(AbstractReflectionConverter.java:100)
at org.geoserver.config.util.XStreamPersister$AbstractReflectionConverter.doMarshal(XStreamPersister.java:1027)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.marshal(AbstractReflectionConverter.java:58)
at com.thoughtworks.xstream.core.TreeMarshaller.start(TreeMarshaller.java:98)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.marshal(AbstractTreeMarshallingStrategy.java:38)
at com.thoughtworks.xstream.XStream.marshal(XStream.java:837)
at com.thoughtworks.xstream.XStream.marshal(XStream.java:826)
at com.thoughtworks.xstream.XStream.toXML(XStream.java:801)
at org.geoserver.config.util.XStreamPersister.save(XStreamPersister.java:396)
at org.geoserver.catalog.rest.AbstractCatalogResource$2.write(AbstractCatalogResource.java:66)
at org.geoserver.rest.format.StreamDataFormat$1.write(StreamDataFormat.java:48)
at com.noelios.restlet.http.HttpServerCall.writeResponseBody(HttpServerCall.java:342)
at com.noelios.restlet.http.HttpServerCall.sendResponse(HttpServerCall.java:306)
at com.noelios.restlet.ext.servlet.ServletCall.sendResponse(ServletCall.java:306)
at com.noelios.restlet.http.HttpServerConverter.commit(HttpServerConverter.java:90)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:130)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: javax.xml.stream.XMLStreamException
at org.codehaus.jettison.mapped.MappedXMLStreamWriter.writeCharacters(MappedXMLStreamWriter.java:171)
at com.thoughtworks.xstream.io.xml.StaxWriter.setValue(StaxWriter.java:119)
... 81 more
... and the .json file results empty.
I think that this problem can depend on the presence of NaN values.
