[Geoserver-devel] [jira] Created: (GEOS-3612) Wrong tiles returned out of a MetaTile if output format is JPEG
                 Key: GEOS-3612
                 URL: http://jira.codehaus.org/browse/GEOS-3612
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.0.0
            Reporter: Gabriel Roldán
            Assignee: Simone Giannecchini
             Fix For: 2.0.1
Found this when using the embedded OL tiling client over an ArcSDE raster. Those are backed by a RenderedImage read from a RawImageInputStream.
Problem is the tiles returned by MetatileMapProduder are subsets of the metatile given by the image's minx/miny/width/height, but the JPEG map producer is alway returning the first tile leading to a sort of repeating pattern map.
The following patch works this around, though I aknowledge it requires a perhaps unwanted image copy, I can't find a better solution for what it seems to be a JAI bug.
{code}
Index: src/main/java/org/vfny/geoserver/wms/responses/map/jpeg/JPEGMapProducer.java
--- src/main/java/org/vfny/geoserver/wms/responses/map/jpeg/JPEGMapProducer.java (revision 13562)
+++ src/main/java/org/vfny/geoserver/wms/responses/map/jpeg/JPEGMapProducer.java (working copy)
@@ -16,6 +16,7 @@
import javax.imageio.ImageIO;
import javax.media.jai.InterpolationNearest;
+import javax.media.jai.PlanarImage;
import javax.media.jai.operator.TranslateDescriptor;
import org.apache.tools.ant.taskdefs.optional.i18n.Translate;
@@ -74,7 +75,16 @@
         if (LOGGER.isLoggable(Level.FINE)) {
             LOGGER.fine("About to write a JPEG image.");
- if (! JPEGNativeAcc.booleanValue()&&image.getMinX()!=0 || image.getMinY()!=0) {
+ if (image instanceof PlanarImage && (image.getMinX() != 0 || image.getMinY() != 0)) {
+ * GR: for the case of JPEG tiles coming from MetatileMapProducer I'm getting a copy of
+ * it because otherwise the ImageWorker writes out the first tile (at 0,0) instead of
+ * the one specified by the image minx and miny
+ image = ((PlanarImage) image).getAsBufferedImage();
+ final boolean jpegNativeAcc = JPEGNativeAcc.booleanValue();
+ if (! jpegNativeAcc&&image.getMinX()!=0 || image.getMinY()!=0) {
           // I don't make an expliciti copy anymore, hoping that sooner or later:
           // A> this bug will be fixed
           // B> JDK JpegImageWriter will stop making a straight copy of the input raster
{code}
For more information on JIRA, see: Jira | Issue & Project Tracking Software | Atlassian
