[Geoserver-devel] [jira] Created: (GEOS-365) LiteRenderer2 still dependent on JAI
         Key: GEOS-365
         URL: http://jira.codehaus.org/browse/GEOS-365
     Project: GeoServer
        Type: Bug
  Components: WMS
    Versions: 1.3-rc1
Environment: Windows XP Professional, JDK1.4.2_05, no JAI installed
    Reporter: Thijs Brentjens
Assigned to: Gabriel Roldán
    Priority: Minor
Sorry for just copy-pasting from an email, but I think it should work :).
On a system without JAI, I've installed Geoserver 1.3.0.RC1. When requesting
for a map (format=image/png), this exception is thrown:
<ServiceExceptionReport version="1.1.1">
<ServiceException
code="">javax/media/jai/util/Range</ServiceException>
</ServiceExceptionReport>
Caused by: java.lang.NoClassDefFoundError: javax/media/jai/util/Range
at
org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:194)
at
org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:165)
at
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:404)
... 39 more
So it seems that there are still some dependencies on JAI. Should I file
this as a bug in JIRA? Or did I misconfigure something? I'm using a JDK
version 1.4.2_05.
Yes, it seems that LiteRenderer2 still depends on this JAI class. As
stated in comments to 'LiteRenderer2.processSymbolizers' this value is
"provided in order to make the style factory happy" :slight_smile: I guess you
should create a jira issue for this, so someone familiar with Geotools
could eventually solve the problem. It is possible that using
Renderer2D will work but I have no idea of how to make it the default
renderer.
For more information on JIRA, see:
