[Geoserver-devel] [jira] Created: (GEOS-3695) Stack trace while trying to add new directory datastore
                 Key: GEOS-3695
                 URL: http://jira.codehaus.org/browse/GEOS-3695
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.1.x
            Reporter: David Winslow
            Assignee: Justin Deoliveira
While trying to add a new directory datastore, I got a stack trace that ended in the following:
Caused by: java.lang.IllegalStateException: No default Namespace configured at org.geoserver.web.data.store.DataAccessNewPage.<init>(DataAccessNewPage.java:49) at org.geoserver.web.data.store.NewDataPage$1$1.onSubmit(NewDataPage.java:82) at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1380) at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:811) ... 71 more
To get this, I started with the 'minimal' dataset, added an 'opengeo' namespace as the default namespace, and deleted 'it.geosolutions' and 'topp' namespaces. Afterwards, the page to create a new datastore failed with that error.
