[Geoserver-devel] [jira] Created: (GEOS-3909) Let the Windows installer add additional entries on the Java Library Path in the wrapper.conf
                 Key: GEOS-3909
                 URL: http://jira.codehaus.org/browse/GEOS-3909
             Project: GeoServer
          Issue Type: Improvement
          Components: Windows Installer
            Reporter: Daniele Romagnoli
            Assignee: Mike Pumphrey
            Priority: Minor
The wrapper.conf produced by the windows installer only contains this line related to the Java library path:
# Java Library Path (location of Wrapper.DLL or libwrapper.so)
wrapper.java.library.path.1=bin/wrapper/lib
All the DLLs (as an instance, the GDAL native libs if deployed) outside that folder aren't loaded by GeoServer when run as Windows Service. Therefore we could add additional lines to this entry where usually native libs will be deployed.
Aime suggested to add <current_jdk>/jre/lib/i386 and <current_jdk>/jre/lib/amd64 as default values and the installer should be able to locate the JDK dir.
