[Geoserver-devel] [jira] Created: (GEOS-3940) Enabling the reverse proxy in web.xml causes the search widget of layers, styles, etc. to malfunction
                 Key: GEOS-3940
                 URL: http://jira.codehaus.org/browse/GEOS-3940
             Project: GeoServer
          Issue Type: Bug
          Components: UI
    Affects Versions: 2.0.x
            Reporter: Luca Morandini
            Assignee: Andrea Aime
In GeoServer-2.0.x (trunk), I noticed the following:
If I set (in web.xml) the reverse proxy filter to true, like in:
<filter>
     <filter-name>Reverse Proxy Filter</filter-name>
     <filter-class>org.geoserver.filters.ReverseProxyFilter</filter-class>
     <init-param>
       <param-name>enabled</param-name>
       <param-value>true</param-value>
The search of layers (and styles too) by their names returns always all items.
When I set enabled to "false" in web.xml and restart GeoServer, OpenLayers layer
preview ceases to work (which is to be expected), but the layer search resume to
work properly.
It resembles this (closed) issue: to http://jira.codehaus.org/browse/GEOS-3757
