[Geoserver-devel] [jira] Created: (GEOS-3995) Build failure caused by unsafe URL-File conversion in KMLMapTransformer
                 Key: GEOS-3995
                 URL: http://jira.codehaus.org/browse/GEOS-3995
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.0.x, 2.1.x
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
            Priority: Blocker
             Fix For: 2.0.3, 2.0.x, 2.1.x
The new behaviour and expanded unit test coverage introduced in r14469 by GEOS-3994 causes the build to fail in a path with spaces. (The broken code existed before; these changes in GEOS-3994 found it.)
While determining the location of a symboliser graphic, we have:
{code}
File file = new File(graphic.getLocation().getFile());
{code}
This is unsafe because it does not unescape URL encoded characters such as spaces. If the graphic is present in a path with spaces, the resulting file does not exist. The solution is to replace this with:
{code}
File file = DataUtilities.urlToFile(graphic.getLocation());
{code}
