[Geoserver-devel] [jira] Created: (GEOS-4169) Dispatcher does not leverage ServiceStrategy abort method
                 Key: GEOS-4169
                 URL: http://jira.codehaus.org/browse/GEOS-4169
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1-beta1, 2.0.2, 1.7.7
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 2.1-beta2
ServiceStrategy.abort() method is there to avoid writing out an incomplete response when a service exception happens.
Using strategies such as the buffer or the file strategy in case of exception the partial output should never be returned.
However, that happens only if the dispatcher calls the abort() method in case of exception, which is not happening
Since the strategy is known only inside the response() method I guess we'd need a try/finally there to do the job
