The direct raster rendering path may fail during reprojection due invalid crop usage
Key: GEOS-4287
URL: http://jira.codehaus.org/browse/GEOS-4287
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1-beta3
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.1-RC1
Attachments: failureSample.png
This happens often when using a tiled client with reprojection, the tiles at the bottom and right of the overall image tend to report the following error:
{code}
05 gen 11:00:58 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at java.lang.Throwable.<init>(Throwable.java:218)
at java.lang.Exception.<init>(Exception.java:59)
at java.lang.RuntimeException.<init>(RuntimeException.java:61)
at org.geoserver.platform.ServiceException.<init>(ServiceException.java:62)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:288)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:205)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:1)
at org.geoserver.wms.GetMap.run(GetMap.java:461)
at org.geoserver.wms.GetMap.run(GetMap.java:110)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:314)
{code}
