[Geoserver-devel] [jira] Created: (GEOS-4306) Image Mosaic dies in fast path with npe
                 Key: GEOS-4306
                 URL: http://jira.codehaus.org/browse/GEOS-4306
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1-RC1
         Environment: Linux ian01.geog.psu.edu 2.6.34.7-63.fc13.i686 #1 SMP Fri Dec 3 12:35:44 UTC 2010 i686 i686 i386 GNU/Linux
            Reporter: Ian Turton
            Assignee: Andrea Aime
When I try to view a coverage from an image mosaic (http://ian01.geog.psu.edu/geoserver/wms?service=WMS&version=1.1.0&request=GetMap&layers=geovista:bluemarbleng&styles=&bbox=-180.0,-90.0,180.0,90.0&width=660&height=330&srs=EPSG:4326&format=application/openlayers) I get the following error:
2011-01-18 13:36:01,861 DEBUG [org.geoserver.filters] - filtering http://ian01.geog.psu.edu/geoserver/wms
2011-01-18 13:36:01,861 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Looking up handler for [/wms]
2011-01-18 13:36:01,862 INFO [org.geoserver.wms] -
Request: getServiceInfo
2011-01-18 13:36:01,862 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2011-01-18 13:36:01,862 DEBUG [org.geoserver.ows] - establishing raster style for geovista:bluemarbleng
2011-01-18 13:36:01,863 DEBUG [org.geoserver.wms] - setting up map
2011-01-18 13:36:01,865 DEBUG [org.geoserver.wms.map] - setting up 660x330 image
2011-01-18 13:36:01,865 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:292)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:209)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:124)
  at org.geoserver.wms.GetMap.run(GetMap.java:461)
  at org.geoserver.wms.GetMap.run(GetMap.java:110)
  at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:338)
  at sun.reflect.GeneratedMethodAccessor193.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:90)
  at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:33)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy21.getMap(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor149.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
  at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
  at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
  at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
  at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
  at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
  at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
  at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
  at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
  at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
  at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
  at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
  at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:879)
  at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
  at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
  at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
  at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
  at java.lang.Thread.run(Thread.java:619)
Caused by: org.geoserver.platform.ServiceException: java.lang.NullPointerException
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:865)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:290)
  ... 141 more
Caused by: java.lang.NullPointerException
  at org.geotools.gce.imagepyramid.ImagePyramidReader.read(ImagePyramidReader.java:351)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.readBestCoverage(RenderedImageMapOutputFormat.java:1179)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:807)
  ... 142 more
