[Geoserver-devel] [jira] Created: (GEOS-4369) Double event notification in Catalog.save
                 Key: GEOS-4369
                 URL: http://jira.codehaus.org/browse/GEOS-4369
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.1-RC1
            Reporter: Gabriel Roldán
            Assignee: Justin Deoliveira
             Fix For: 2.1-RC2
Just found that when saving a {{StyleInfo}} the catalog issues the same post modification event twice. This is inconvenient cause there might be listeners performing expensive actions.
The call chain goes like:
{code}
CatalogImpl.save(style)
     |--> DefaultCatalogFacade.save(style) -> DefaultCatalogFacade.saved(style) -> CatalogImpl.firePostModified(unwrapProxy(style))
     |--> CatalogImpl.saved(style) --> CatalogImpl.firePostModified(style)
{code}
Actually it looks like that's the case for all the CatalogImpl.save() overrides. It doesn't look like DefaultCatalogFacade issues events for {{add(...)}} nor {{remove(....)}}, so maybe it's just an unintentional left over in {{DefaultCatalogFacade}} that should not trigger events?
