Make geoserver.war working on JBoss 6 Final
Key: GEOS-4399
URL: http://jira.codehaus.org/browse/GEOS-4399
Project: GeoServer
Issue Type: Improvement
Affects Versions: 2.1-RC2
Reporter: Fredrik Holmqvist
Assignee: Andrea Aime
Priority: Minor
JBoss 6 Final have several issues with GeoServer:
* annotation scanning get stuck in recursive loop causing stack overflow
* incompatible versions of xml parsers causing class cast exception.
While this is not a problem in GeoServer, adding configuration for jboss can solve this. I do not know if this is desirable, but at least I document it here.
The following files need to be added to WEB-INF:
* context.xml
* jboss-classloading.xml
* jboss-scanning.xml
{code:title=WEB-INF/context.xml|borderStyle=solid}
<!-- To use GeoServers xml parsers and not JBoss6 as they seem incompatible -->
<Context/>
{code}
{code:title=WEB-INF/jboss-classloading.xml|borderStyle=solid}
<classloading xmlns="urn:jboss:classloading:1.0"
name="geoserver.war"
domain="GeoserverDomain"
export-all="NON_EMPTY"
import-all="true">
</classloading>
{code}
{code:title=WEB-INF/jboss-scanning.xml|borderStyle=solid}
<!-- Turn of jee annotation scanning. JBoss 6 don't handle cyclic dependcies, and GeoServer don't have annotations so it is faster anyways. -->
<scanning xmlns="urn:jboss:scanning:1.0"/>
{code}
