The direct rendering path expands grayscale images to RGB even when not necessary
Key: GEOS-4405
URL: http://jira.codehaus.org/browse/GEOS-4405
Project: GeoServer
Issue Type: Improvement
Affects Versions: 2.1-RC2
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.0.3
The code should check if the background color is some sort of gray (all components having the same value and alpha being 255), in that case color expansion is not necessary
