[Geoserver-devel] [jira] Created: (GEOS-4439) When I try to add a not reachable EXTERNAL storage (via REST) I get a NullPointerException
                 Key: GEOS-4439
                 URL: http://jira.codehaus.org/browse/GEOS-4439
             Project: GeoServer
          Issue Type: Improvement
         Environment: I have a cifs share as data storage which is used to share data between two server:
1- The GeoBatch server (192.168.1.X)
2- The GeoServer (192.168.1.Y)
3- The cifs share (192.168.1.Z)
            Reporter: carlo cancellieri
            Assignee: Andrea Aime
             Fix For: 2.1.0, 2.0.x, 2.1.x
How to reproduce:
when i call: (from the geobatch server)
final String layerResponse = GeoServerRESTHelper.sendCoverage(inputDir, inputDir,
                decurtSlash(config.getGeoserverURL()), config.getGeoserverUID(), config.getGeoserverPWD(),
                mosaicDescriptor.getCoverageStoreId(), mosaicDescriptor.getCoverageStoreId(), queryParams,
                "", "EXTERNAL", "imagemosaic", GEOSERVER_VERSION, config.getStyles(),
                config.getDefaultStyle());
I get (on geobatch):
                layerResponse==null
This call should create a store (on GeoServer) using a shared mount point (let's use Z:/media/bigdisk/data).
This mount point should be available from the X and Y servers but it don't.
For some reason the Y server was not able to mount the share so I got an error on the request but that error was not so explicit:
I got (on geoserver):
01 Mar 11:29:57 ERROR [geoserver.rest] -
java.lang.NullPointerException
        at org.geoserver.catalog.rest.CoverageStoreFileResource.handlePut(CoverageStoreFileResource.java:88)
        at org.restlet.Finder.handle(Finder.java:298)
        at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
        at org.restlet.Filter.doHandle(Filter.java:105)
        at org.restlet.Filter.handle(Filter.java:134)
        at org.restlet.Router.handle(Router.java:444)
        at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
        at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
        at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
        at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:521)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:640)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
        at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
        at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
        at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
        at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
        at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
        at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
        at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
        at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
        at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
        at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
        at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
        at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
        at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
        at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
        at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
        at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
        at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
        at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
        at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
        at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
        at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
        at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
        at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
        at java.lang.Thread.run(Thread.java:662)
After may other changes and debug cycles on the GeoBatch module I looked into the GeoServer machine discovering that the EXTERNAL storage was not mounted....
I think a message like this will save a lot of debugging time:
CoverageStoreFileResource: FileNotFound -> unable to locate file /PATH/TO/FILE on the filesystem (EXTERNAL storage).
what do you think?
Thank you,
Carlo Cancellieri
