Build failure in control-flow ControlFlowCallbackTest
Key: GEOS-4555
URL: http://jira.codehaus.org/browse/GEOS-4555
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.2.x
Environment: Apache Maven 2.2.1 (r801777; 2009-08-07 03:16:01+0800)
Java version: 1.5.0_22
Java home: /home/car605/junk/java/jdk1.5.0_22.i586/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: "linux" version: "2.6.35.13-91.fc14.x86_64" arch: "i386" Family: "unix"
and
Java home: /opt/jdk1.5.0_22/jre
Default locale: en_AU, platform encoding: UTF-8
OS name: "linux" version: "2.6.32-5-686" arch: "i386" Family: "unix"
Reporter: Ben Caradoc-Davies
Assignee: Andrea Aime
Priority: Blocker
Looks like some sort of test race condition in ControlFlowCallbackTest that fails on our buildbot and locally in maven. Test passes in Eclipse and on OpenGeo Hudson.
{code}
Test set: org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.224 sec <<< FAILURE!
testBasicFunctionality(org.geoserver.flow.ControlFlowCallbackTest) Time elapsed: 0.004 sec <<< FAILURE!
junit.framework.AssertionFailedError: expected:<1> but was:<0>
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.Assert.failNotEquals(Assert.java:280)
at junit.framework.Assert.assertEquals(Assert.java:64)
at junit.framework.Assert.assertEquals(Assert.java:198)
at junit.framework.Assert.assertEquals(Assert.java:204)
at org.geoserver.flow.ControlFlowCallbackTest.testBasicFunctionality(ControlFlowCallbackTest.java:22)
{code}
