[Geoserver-devel] [jira] Created: (GEOS-4578) resource loader createDirectory may fail to create directories without throwing
                 Key: GEOS-4578
                 URL: http://jira.codehaus.org/browse/GEOS-4578
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1.0
            Reporter: Tim Schaub
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: createDir.patch
The return on mkdirs in createDirectory is not checked so the method can fail to create directories without throwing.
I don't see other tests to crib from, so I'll attach a patch without. Basically, if you have a file named "foo" in your data dir and try to create a directory named "foo/bar" you can reproduce this.
{code}
// with a file named "foo" in the data dir
GeoServerResourceLoader resourceLoader = GeoServerExtensions.bean(GeoServerResourceLoader.class);
resourceLoader.findOrCreateDirectory("foo/bar"); // doesn't throw IOException
{code}
Patch attached against trunk at r15943.
