Build failure in community/dds in geoserver-trunk-nightly caused by WMS changes
Key: GEOS-4612
URL: http://jira.codehaus.org/browse/GEOS-4612
Project: GeoServer
Issue Type: Bug
Components: Community modules
Affects Versions: 2.2.x
Reporter: Ben Caradoc-Davies
Assignee: Tisham Dhar
Priority: Blocker
Fix For: 2.2.x
The change:
GEOS-3754: Add support for TIME and ELEVATION parameters, vector part
caused geoserver-trunk-nightly to fail in community/dds:
{code}
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dds/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dds/src/main/java/org/geoserver/wms/worldwind/DDSMapResponse.java>:\[22,7\] org.geoserver.wms.worldwind.DDSMapResponse is not abstract and does not override abstract method getCapabilities(java.lang.String) in org.geoserver.wms.map.RenderedImageMapResponse
<http://hudson.opengeo.org/hudson/job/geoserver-trunk-nightly/ws/geoserver_trunk/src/community/dds/src/main/java/org/geoserver/wms/worldwind/BilMapResponse.java>:\[63,13\] org.geoserver.wms.worldwind.BilMapResponse is not abstract and does not override abstract method getCapabilities(java.lang.String) in org.geoserver.wms.map.RenderedImageMapResponse
{code}
The change that caused it added a new abstract method:
{code}
diff --git a/src/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapResponse.java b/src/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapResponse.java
index 72c08b3..4153bc3 100644
--- a/src/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapResponse.java
+++ b/src/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapResponse.java
@@ -15,6 +15,7 @@ import javax.media.jai.PlanarImage;
import org.geoserver.platform.Operation;
import org.geoserver.platform.ServiceException;
import org.geoserver.wms.GetMapOutputFormat;
+import org.geoserver.wms.MapProducerCapabilities;
import org.geoserver.wms.WMS;
import org.geoserver.wms.WMSMapContext;
import org.geotools.coverage.grid.GridCoverage2D;
@@ -139,4 +140,10 @@ public abstract class RenderedImageMapResponse extends AbstractMapResponse {
return ImageUtils.forceIndexed8Bitmask(originalImage, paletteInverter);
+ * Returns the capabilities for this output format
+ * @param outputFormat
+ * @return
+ public abstract MapProducerCapabilities getCapabilities(String outputFormat);
{code}
