Remove old doc stuff from SVN
Key: GEOS-468
URL: http://jira.codehaus.org/browse/GEOS-468
Project: GeoServer
Type: Sub-task
Components: Documentation
Versions: 1.3.0 RC6
Reporter: Chris Holmes
Assigned to: dblasby
Fix For: 1.3.0 RC7
With everything successfully in wiki, we can get rid of some random crap in svn. Most obvious is the docbook xml that made up the old docs. But there's also a lot of crap, as we embedded jars and such to do the docbook transform. Also get rid of all references in the ant tasks. This should hopefully leave things much cleaner. If you are unsure on what you're allowed to delete then just pass this task over to me.
For more information on JIRA, see:
[ http://jira.codehaus.org/browse/GEOS-468?page=all ]
Chris Holmes reopened GEOS-468:
All the actual docbook documents are still there...
Key: GEOS-468
Project: GeoServer
Type: Sub-task
Versions: 1.3.0 RC6
Assignee: Chris Holmes
Fix For: 1.3.0 RC7
