Co-ordinates flipped when serving WCS
Key: GEOS-4732
URL: https://jira.codehaus.org/browse/GEOS-4732
Project: GeoServer
Issue Type: Bug
Components: WCS
Affects Versions: 2.1.1
Environment: CentOS 6, amd64
Reporter: Peter Follo
Assignee: Andrea Aime
Attachments: bug.txt
This is probably related to GEOS-3241 but it's fairly old and I wanted to point out it's still present in 2.1.1 and provide more info if asked for.
Geoserver seems to flip coordinates when serving geotiffs via WCS, attached is output from gdalinfo from serverside file and served file. Note that the coordinates are flipped. Looking att the same raster via WMS/openlayers shows correct un-flipped coordinates. The attachment also contains the result from 'Generate GetCoverage XML'
