[Geoserver-devel] [jira] Created: (GEOS-4755) ImagePyramid properties getting clobbered.
                 Key: GEOS-4755
                 URL: https://jira.codehaus.org/browse/GEOS-4755
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.1, 2.1.0
         Environment: linux, jetty, java version "1.6.0_27"
            Reporter: Gordon Keith
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: geoserver_public
An image pyramid works for a while, then the properties etc files get overwritten by geoserver with a version that are useless. After the overwrite the GetMap request reports a NullPointerException and a GetCapabilities request produces an error.
Before the overwrite the layer looks like this:
l
drwxrwxr-x 12 kei037 geoserver 4096 2011-09-07 11:50 ./
drwxrwxr-x 11 geoserver geoserver 4096 2011-09-06 10:51 ../
drwxrwxr-x 2 kei037 geoserver 49152 2011-09-06 15:27 1/
drwxrwxr-x 2 kei037 geoserver 4096 2011-09-01 15:44 128/
drwxrwxr-x 2 kei037 geoserver 4096 2011-09-06 15:27 16/
drwxrwxr-x 2 kei037 geoserver 20480 2011-09-06 15:27 2/
drwxrwxr-x 2 kei037 geoserver 4096 2011-09-01 15:44 256/
drwxrwxr-x 2 kei037 geoserver 4096 2011-09-06 15:27 32/
drwxrwxr-x 2 kei037 geoserver 12288 2011-09-06 15:27 4/
drwxrwxr-x 2 kei037 geoserver 4096 2011-09-01 15:44 512/
drwxrwxr-x 2 kei037 geoserver 4096 2011-09-06 15:27 64/
drwxrwxr-x 2 kei037 geoserver 4096 2011-09-06 15:27 8/
-rw-rw-r-- 1 kei037 geoserver 336 2011-09-06 15:26 mpa_bathy.prj
-rw-rw-r-- 1 kei037 geoserver 292 2011-09-06 15:27 mpa_bathy.properties
more mpa_bathy.pr*
mpa_bathy.prj
GEOGCS["WGS 84", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM
["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Geodetic longitude", EAST], AXIS["Geodetic latitude", NORTH], AUTHOR
ITY["EPSG","4326"]]
Name=mpa_bathy
Envelope2D=110,-64 174,0
LevelsNum=10
LevelsDirs=1 2 4 8 16 32 64 128 256 512
Levels=0.000245,0.000245 0.000489,0.000489 0.000978,0.000978 0.001957,0.001957 0.003914,0.003914 0.007828,0.007828 0.015656,0.015656 0.031311,0.031311 0.06262
2,0.062622 0.125245,0.125245
After the overwrite the layer looks like this:
-rw-r--r-- 1 geoserver geoserver 231860 2011-09-07 11:50 mpa_bathy.dbf
-rw-r--r-- 1 geoserver geoserver 10921 2011-09-07 11:50 mpa_bathy.fix
-rw-r--r-- 1 geoserver geoserver 335 2011-09-07 11:49 mpa_bathy.prj
-rw-rw-r-- 1 kei037 geoserver 300 2011-09-07 11:50 mpa_bathy.properties
-rw-r--r-- 1 geoserver geoserver 11352 2011-09-07 11:50 mpa_bathy.qix
-rw-r--r-- 1 geoserver geoserver 123724 2011-09-07 11:50 mpa_bathy.shp
-rw-r--r-- 1 geoserver geoserver 7372 2011-09-07 11:50 mpa_bathy.shx
-rw-r--r-- 1 geoserver geoserver 1452 2011-09-07 11:50 sample_image
more mpa_bathy.pr*
mpa_bathy.prj
ITY["EPSG","4326"]]
#-Automagically created from GeoTools-
#Wed Sep 07 11:50:16 EST 2011
Levels=9.78473581E-4,9.78473581E-4
Heterogeneous=true
AbsolutePath=false
Name=mpa_bathy
Caching=true
ExpandToRGB=false
LocationAttribute=location
SuggestedSPI=it.geosolutions.imageioimpl.plugins.tiff.TIFFImageReaderSpi
LevelsNum=1
This happens with a variety of ImagePyramids.
Attached is the log of standard out.
