[Geoserver-devel] [jira] Created: (GEOS-480) Clean up build file and other files
         Key: GEOS-480
         URL: http://jira.codehaus.org/browse/GEOS-480
     Project: GeoServer
        Type: Task
  Components: Configuration
    Versions: 1.3.0 RC6
    Reporter: Chris Holmes
Assigned to: dblasby
    Priority: Minor
     Fix For: 1.4
So I'm moving around a few files for DATA_DIR stuff, and I'd really like to clean up a lot more, but shouldn't as we're trying to really stabilize for 1.3.0 release, and all these little changes could add up to problems.
The biggest is I'd like to rename the capabilities/ directory to schemas/ to more accurately reflect what's actually in it. This should be an easy change, since you can just change the value of util/Requests to return a different base directory.
The build file also has a lot of cruft, that should just be picked over and figure out what's actually needed. Like in the war files are copied to a build.dir, but then the building of the war doesn't seem to actually use these. There's also a log4j props file that gets copied over and then removed at the end. I'm sure the other targets will reveal other things like this.
For more information on JIRA, see:
