Using Monitoring into an Oracle DB fails due to use of reserved word RESOURCE as a column name
Key: GEOS-4871
URL: https://jira.codehaus.org/browse/GEOS-4871
Project: GeoServer
Issue Type: Bug
Components: Community modules
Affects Versions: 2.1.2
Environment: Monitoring DB - Oracle
Reporter: Martin Davis
Assignee: Andrea Aime
Monitoring creates a table
REQUEST_RESOURCES
(REQUEST_ID number(19,0) not null, RESOURCE varchar2(255 char), IDX number(10,0) not null, primary key (REQUEST_ID, IDX))
RESOURCE is a reserved word in Oracle SQL, so using Monitoring into an Oracle DB fails during schema creation.
The fix is to change the column name - Justin suggests NAME.
Upgrade of existing installs may be able to be done automatically via Hibernate "hibernate.hbm2ddl.auto" configuration option. Otherwise, users should be informed to manually alter the table when upgrading.
