EnvelopePanel rounds bounds coordinates to three decimals
Key: GEOS-4887
URL: https://jira.codehaus.org/browse/GEOS-4887
Project: GeoServer
Issue Type: Bug
Components: Wicket UI
Affects Versions: 2.1.2
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 2.1.3
EnvelopePanel uses wicket TextField for the bounds coordinates. TextField rounds numbers to three decimals.
This is inconvenient for certain uses of EnvelopePanel if more accuracy is needed. For instance, in order to use it to define a gwc gridset coordinate (work in progress on a branch), it is needed that the bounds coordinate are as accurate as possible as one bbox corner is used as tile origin.
Solution is to use a TextField subclass that provides an alternative IConverter that allows for more decimal places.
