Typos in db2-readme.txt in "DB2 extra"
Key: GEOS-658
URL: http://jira.codehaus.org/browse/GEOS-658
Project: GeoServer
Type: Bug
Environment: All
Reporter: David Adler
Assigned to: dblasby
Priority: Trivial
Fix For: 1.3.2
The db2-readme.txt refers to the mysql jars.
I've included the corrected text below:
GEOSERVER 1.3.1+ DATA STORE EXTRAS README
This package contains a DB2 DataStore implementation that is
distributed as a separate plug-in.
Please report any bugs with jira (http://jira.codehaus.org/browse/GEOS).
Any other issues can be discussed on the mailing list (http://lists.sourceforge.net/lists/listinfo/geoserver-users).
Contains the following data stores:
INSTALLATION
1. Copy the included gt2-db2 jar to your
GeoServer library directory. In a binary install this is at
[GEOSERVER_HOME]/server/geoserver/WEB-INF/lib/
In a war install this is [container]/webapps/geoserver/WEB-INF/lib/
2. Copy db2jcc_license_cu.jar and db2jcc.jar from the DB2 instance installation directory
$DB2PATH/java to your GeoServer library directory.
3. Restart GeoServer.
DB2 should now show up as an option in the web admin tool at
Config -> Data -> Stores -> New. Fill out the appropriate params. For more
information see http://docs.codehaus.org/display/GEOSDOC/DB2+DataStore
COMPATIBILITY
This jar should work with any version of GeoServer based on GeoTools 2.2.x.
Currently this is anything in 1.3.x above 1.3.1. GeoServer 1.4 should also
be compatible.
For more information on JIRA, see:
Where does this file reside? When I look in the following I see a much older (more obsolete) version
https://svn.codehaus.org/geoserver/trunk/geoserver/ext/db2/README-db2.txt
Key: GEOS-658
Project: GeoServer
Type: Bug
Environment: All
Priority: Trivial
Fix For: 1.3.2
INSTALLATION
COMPATIBILITY
be compatible.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Oh, I didn't realize we had a place for these jars. Right now it resides on my hard drive, just needed to get it done fast, was going to figure out a place to put them later. I'll commit what I've got in a bit.
C
Key: GEOS-658
Project: GeoServer
Type: Bug
Environment: All
Priority: Trivial
Fix For: 1.3.2
INSTALLATION
COMPATIBILITY
be compatible.
!DSPAM:1003,44b3fecf248892051017194!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
